error codes F1E9 or E9F1
Kitchenaid dishwasher #KDPM804KPS
Start Dishwasher on normal cycle time is 2:53 minutes count down, it get to 46 minutes
And stop counting down this last for 12 minutes and then start flashing F9E1 error code,
when I open it up the hot steam comes out but water is standing on the bottom
as high as the bottom of heating element .
Now if I let it cool down and press cancel and drain it drain just fine
or if I only use the rinse only cycle it works fine, I have replace the control board
and the same thing happens?
It is only two years old.
Thank you
Esta é uma boa pergunta?
Did you ever figure out the issue? Having same problem…
por Derick Brady
