Ir para o conteúdo principal
Reparo e suporte para os controles que acompanhavam o PS3. Lançado em novembro de 2007 (apenas no Japão) e em 2008 (outros países), o controle com bateria de lítio e seis eixos (CECHZC2) é simples de consertar.
Why is 4 red lights blinking?
I recently took apart my DS3 and put it back together, ever since then I have received 4 flashing red lights everytime i plug it in. It does not give off any lights when unplugged
Edit: I have used the reset button and switched batteries.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Sounds like the board isn't connected to the battery properly and isn't charging. Open it up and check all the connections.
Esta resposta foi útil?
Pontuação 0
9 comentários:
Hey and thanks for answering! Shouldn't the controller work with unplugged battery whilst connected with usb?
por Compartilhar
@thimstr I don't think so. Usb is purely for charging and not actual power.
por Compartilhar
@strongbow Well, I switched with a brand new battery yesterday and I got the exact same results, sorry for not providing this info firsthand.
por Compartilhar
@thimstr obviously the battery is connected. Have you tested voltage to the battery connector with a multimeter with the cable connected? Check the voltage on the new battery too.
por Compartilhar
@strongbow Thanks for the suggestion, I would have to bring home a multimeter from work, is there anything else I could check in the meanwhile?
por Compartilhar
Exibir mais 4 comentários
Adicionar a sua resposta
Thim Strömberg será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 17
Últimos 30 dias: 63
Ao todo: 1,998
