Ir para o conteúdo principal
Este é um controlador com tela tátil associado ao console de jogo Wii U. Foi lançado em 18 de novembro de 2012 e disponibilizado nas cores preta ou branca. Número do modelo: WUP-010(EUA)
Wii U Gamepad touchscreen problem
i Took out my Wii U a while ago and decided to start to play again.
I have a gamepad from 2014 with the screen having minor damages. I decided to turn it on one day and the gamepad wont let me move the control sticks as the gamepad is imputing a signal from the touchscreen. the screen is responsive but it wont input any other areas of the screen for a while.
Calibrating didn't fix the issue and I'm starting to think the scratches could be the problem and I just have to buy a new digitizer. the LCD screen has no damage at all and works perfectly fine.
I have the necessary tools to open it up and replace the screen but I'm willing to ask if there is any other way to fix the problem or if I need to buy a replacement for the gamepad
Thanks everyone!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@sn2804 that would be a great start to replace the digitizer
https://www.amazon.com/Timorn-Replacemen...
but if that doesn't work, you could take it to a shop instead of replacing the unit as a whole, as they may know what is wrong
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Santiago será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 406
