Ir para o conteúdo principal
The larger version of Samsung's flagship phone, the Galaxy S8+. Released in April 2017.
WhatsApp calls with Bluetooth headset
When I'm using a Bluetooth Headset and I make a WhatsApp call, my friend will stop hearing me as soon as the screen of my phone goes on standby. Have you experienced that before and what can I do.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Set the screen to either stay on longer or not turn off. Be warned, depending on phone you could be causing screen burn by doing it. When the screen goes off it basically closes the app, ending the call so to speak. There may be something in permissions you can change.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thank you for your response, that is what i currently do, however, you should note that this is not good for the battery and it can also burn the screen. I will appreciate if anyone knows the permission that can be activated or changed.
Thank you Nigel
por
Adicionar a sua resposta
Kunle Olagunju será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 145
