How can I change the battery of my Samsung CLX-3185FW printer?
How can I change the lithium battery for this printer?
I have no idea how to remove panel 7 on the attached diagram?
Can anyone help me please?
Thanks!
Esta é uma boa pergunta?
Thanks!
I was finally able to open the right side panel (7) of the printer after using much force and lifting it upwards. Definitely not easy!
Once the panel withdrawn, the battery location is very easy to find.
Esta resposta foi útil?
Before I open mine up, do you recall the type of battery? Thanks, and cheers!
Nope I don't but that's an easy one to find in retail shops.
Últimas 24 horas: 8
Últimos 7 dias: 16
Últimos 30 dias: 42
Duração total: 1,002
3 comentários
Hi @fof1252
Looking at the image you posted, it seems that there is a screw shown between panel 7 and the right hand edge of the image you posted. It looks like a small dot but if you hover your cursor over the image you posted and click on the magnifying icon the image will enlarge and it is quite clear. It is all by itself.
Check if there is a screw roughly in that area of the panel as shown in the image. Maybe that's what holding the panel in place.
por jayeff
Unfortunately I already tried this and it is not enough :-(
por fof
By the way I found the diagram here:
https://h30434.www3.hp.com/t5/Samsung/CL...
por fof
