LED n2 does not light up
Hello. LED n2 does not light up, what could be the problem? How could I check it? Is it necessary to have the ram and processor mounted on the motherboard for it to turn on? Thanks
Esta é uma boa pergunta?
andre.dias.tui you are looking at LED 1 which means you need to check LED Startup Sequence
LED #1 = Power available.
If LED 1 is on but LED 2 does not come on, you will need to check:
• Verify power button connection to logic board
• Verify power button functionality
• Verify cable connection between power supply and logic board
• Verify power supply
• Verify logic board
I would start by checking the power board voltage output to the logic board. You can measure that on the power connector from the power supply.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 18
