Ir para o conteúdo principal
Suporte para a calculadora Texas Instruments TI-84 Plus.
Fix battery spring on calculator
I have a calculator that had been working well but the batteries rotted inside. Taking them out one of the springs came undone. Is this fixable?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi
The best thing you can do is dismantle the calculator and solder the battery connection back on
Here’s a guide for that
Desmontagem da TI-84 Plus
If the battery’s had leaked you may need to order new ones
I would also take this opportunity to make sure no other parts of the calculator got effected by the battery leaking:-)
Hopefully this helps
Any questions please ask
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Jasmine Kalta será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 14
Ao todo: 389
