Why is wifi not working
When i switch on wifi, it does not show available routers & it does not access any wifi connection
Esta é uma boa pergunta?
Hi,
Try using the phone's WiFi as close as possible to your network router i.e. <10cm and check if it detects the networks and connects to it.
If it does then it may be a loose antenna problem.
Here's an image of the phone taken from a teardown video that shows the antenna connections at both ends of the phone.
(click on image)
If it still doesn't work it may be a problem on the systemboard. Here's an image of the no BT/WiFi troubleshooting flowchart that may help.
(click on image)
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 322
2 comentários
WiFi not work
=== Update (05/11/24) ===
Samsung A10 WiFi not work
por Nauman rajput bhtti
