Ir para o conteúdo principal
Guias de reparo e informações acerca de desmontagens de diversos celulares Samsung, velhos e novos, incluindo a famosa linha Galaxy. Tudo o que você precisa para consertar por conta própria o seu celular Samsung.
13255 Perguntas Visualizar todos
Samsung phone is not starting or not charging
My samsung galaxy Star Plus Model no- GT-S7262 stopped working like 2 year ago. On that time were not known about Firmware issue so we left it like it is now. After 2 year knowing the firmware problem i tried to restart it but nothing happening. Is there any chance to reopen and reuse it?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
I'm sorry to hear that your Samsung Galaxy Star Plus has stopped working. Unfortunately, it is unlikely that you will be able to get it running again without replacing the firmware. It is possible to replace the firmware with a compatible version, but this can be quite complicated and may require professional assistance. Additionally, there may be other hardware or software issues preventing the phone from functioning properly even if you are able to replace the firmware. I recommend consulting a certified technician for advice on how best to proceed.
Esta resposta foi útil?
Pontuação 0
@debojit first, after two years your battery will need to be replaced. Second, what made you determine that this is a firmware issue. You did not tell us what you did, that may have caused this. So change the battery, get a USB ammeter plug your phone in and see how many amps it pulls first. Lets see if this is not a different issue.
You can try to update your firmware by following these instructions
Pontuação 0
MY phone is not starting and not showing anything on the screen
Pontuação 0
1 comentário:
@dilipkumar82495 what make and model is your phone? What have you checked and what have you tried?
por
Adicionar a sua resposta
Debojit será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 13
Duração total: 48
