Ir para o conteúdo principal
O Corsair Gaming K70 é um teclado gamer totalmente mecânico com um chassi de alumínio escovado anodizado para um visual e toque de nível profissional.
How to replace the volume nob
I broke the volume not on my corsair k70 mk2 and while I had it I found it really useful but I can't find a replacement part online and it is really bugging me because I dont want to have to buy a complete new keyboard
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Hello, i'have the same problem, did you find a remplacement wheel ?
Thanks !
por Compartilhar
Adicionar um comentário
1 resposta
Pergunta mais útil
There is a screw under the trim ring on the side of the volume wheel. If you take off all of the keys to see the screws to take off the backplate, there is one that is not easily seen as you need to pry that silver trim ring off the right side and there is the last screw under there. From there, replacement of the wheel is pretty simple.
Esta resposta foi útil?
Pontuação 2
1 comentário:
I simply sprayed with a electronic cleaner foam and blew out with air and wiped off wheel and its solved all my scrolling skipping issues and got it back to excellent accuracy, if the scrolling is functional, but the accuracy is messed up.
por Compartilhar
Adicionar a sua resposta
Healer WR será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 20
Últimos 30 dias: 63
Ao todo: 1,779
