Ir para o conteúdo principal
Modelo A1418 / Meados de 2014 / Processador Core i5 de 1,4, 2,7 e 2,9 GHz ou Core i7 de 3,1 GHz
Display backlight not working
I dissembled my device to replace a HDD with a new SSD. When I put everything back, all the components worked flawlessly. However, when it go to sleep mode, the backlight not turn back on, I still can see the content on display if I shine the flashlight on it. Every time I want to get backlight back on, I had to unplug the device and leave it there for a while, then plug it back and turn on.
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
@hellomacos - You might be able to help this person!
por
@beanman56
Thanks for tagging me in:-)
por
Hi
It might be worth disassembling the device again and examining the board for anything that looks blown(burned discoloured)
I would also try a SMC Reset
https://support.apple.com/en-gb/HT201295
por
Adicionar um comentário
1 resposta
Based on the information provided, it is possible that the issue may be caused by a malfunctioning backlight circuit or a loose connection between the display and backlight components.
To fix this issue, you could try the following steps:
  1. Check the connections between the display and backlight components to make sure they are properly seated and not loose.
  2. Update the display and graphics drivers on your device.
  3. Check the power settings and ensure that the display is set to turn on after waking from sleep mode.
  4. Reset the device's PRAM (Parameter Random Access Memory) and NVRAM (Non-Volatile Random Access Memory).
  5. If the issue persists, it may be necessary to replace the backlight or other components.
It is important to note that opening and attempting to repair electronic devices can be dangerous and may void any warranties. If you are unsure about any of the steps or do not have the necessary technical skills, it may be best to seek professional help from an authorized repair service or contact the manufacturer for assistance.
Esta resposta foi útil?
Pontuação 0
1 comentário:
I checked them carefully and several times. All the sockets are good, no exploded components on the mainboard. I have one big concern about the PRAM battery, does a weak CMOS battery cause this issue?
por
Adicionar a sua resposta
Khôi Trần será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 17
Ao todo: 404
