Is this model a dual voltage laptop?
I'm moving out of the US to a European country and would like to still use this Acer in my new home. I don't know if it's a dual-voltage laptop.
Esta é uma boa pergunta?
The laptop works off a 19-20V charger input regardless of your location. What you need to check is your laptop charger and make sure it is able to handle both 110VAC (US) or 240VAC (EU). There is usually a sticker on the underside of the charging adapter which tells you what are the input voltages for your charger (Usually 100-240V).
Hope it helps!
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 242
