Ir para o conteúdo principal
Repair information for the Sony Bravia 42" LCD TV. Released in 2012. Model number: KDL42EX440.
16 Perguntas Visualizar todos
How do I do away with horizontal lines seen on my tv screen?
Esta pergunta é pertinente?
Pontuação 0
1 dos comentários:
@kelly_jn that will depend on what they look like. Horizontal lines are almost exclusively indicative of a bad panel. We would need to see what you got going on there. Post some pictures of what your screen shows. Adicionar imagens a uma pergunta já existente
We will also need to know your TV's exact model number
por
Adicionar um comentário
1 Resposta
could be a loose connection inside or might be a dying backlight or inverter. you can check the connections if you feel like opening it up. if that’s not the problem and if it’s worth it to you to fix it you can probably find replacement parts easily and look up the repair/maintenance manual for the repair procedure
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Joe Kelly Jnr será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 17
