Ir para o conteúdo principal
Modelo: PowerShot SX700 HS (PC2091/PC2093/2047) Nº do corpo: 902053007176 Lançamento: abril de 2014
Pop up flash problems
I have two Canon SX 700 HS cameras. Each with a different flash problem.
On the first, the flash works, but the internal catch to hold it down is either broken or disconnected so it won't stay down.
On the second, the flash physically works in place, but the settings and flash don't function or flash.
I'd like to fix both, but if need be, use one to fix the other. Is there anywhere I can find schematic drawings of this camera so I can get into it without blind luck?
Any suggestions would be appreciated.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @drkenrich
For the broken catch problem here's a link to the parts catalogue if you're willing to buy it.
Can't find the schematic and the supplier linked above doesn't show it but perhaps you can ask them if they have it.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Ken Rich será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 37
Ao todo: 477
