How do I fix this?
if the image doesn’t work here’s the issue I’m having… my 70 inch rca led 4K smart tv has white purple yello lines going through the screen is it easy to fix ?
Esta é uma boa pergunta?
Jacob Thurston looks like you have horizontal as well as vertical lines etc. this actually looks like a panel error. You can try and replace the main board and see if that makes a difference. Of course, also check all the LVDS cables making sure they are not torn, corroded etc. Ultimately this looks like a bad panel .
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 28
Duração total: 271
