Ir para o conteúdo principal
Guias de reparo e desmontagem para reprodutores de DVD da Panasonic.
DVD recorder does not recognize new blank disks
My Panasonic VHS to DVD recorder is not recognizing blank disks. With DVD-R it says the disk is damaged each time one is inserted. With +R, it goes through the formatting process, but says it is still blank upon completion. What are my options? I have used a lens cleaning disk and compressed air to remove debris.
Update (02/14/2023)
It's a Panasonic ES35V
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
@rajah are you using the right disks for your recorder? Some are really finicky about that. What make and model is your recorder?
por
Adicionar um comentário
1 resposta
@rajah59 looks like it will only allow you to do DV video REcording on DVD-Ram disks. Anyhow, check the user manual DMR ES35V page 6 and on, about which disk type allows you what recording. Looks to me like the safest bet are DVD-Ram disks.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Rajah59 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 23
Ao todo: 632
