How do you test for a bad panel - other than replacing all the boards?
My UN60EH6050FXZA has sound & backlight, but no picture from the start - even with flashlight test.
My BN95-00628C T-con does have 12v at both ends of the fuse, so does this mean it is NOT likely to be the Main Board?
Neither half of the screen comes on when I disconnect either one of the two ribbons from the T-con board to the panel. So does that mean it is NOT likely the panel? But I've read other panel problems.
There is no voltage at the two twin “commonly failing” T-con board capacitors, which I understand typically have 35 volts. (the ones often sold in repair kits, along with an IC chip). Does this definitely mean a bad T-con board? Or could it still be panel - maybe even causing the T-con to fail? Thanks.
Esta é uma boa pergunta?
