Ir para o conteúdo principal
Guias de reparo e suporte para o Expedition, um SUV de tamanho grande baseado na picape F-150 da Ford. Estreitamente relacionado ao Lincoln Navigator.
Power locks just quit working
Power locks just quit working all together. Checked fuses, replaced door button, and replaced power lock/anti theft actuator and still nothing
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
These are all controlled via the Body Control Module. This type of vehicle has some of this operation built into the engine computer too. The relays carbon-up &/or go dry-jointed inside of the BCM's. They need a re-work and relay contacts all need cleaning, which you can do yourself by pinching a non-glossy business card between the relay contacts and sliding it out until the black carbon trace disappears. De-solder, clean, flux, re-solder dry joints on relays and connectors. I've personally done hundreds over many years.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Josh será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 383
