Ir para o conteúdo principal
The second generation was introduced as a 2003 model at the 2002 Chicago Auto Show, based on the new Impreza platform, featuring several fine-tune improvements over the past model.
Subaru forester 2006 Cruise SET Control Light Flashing
Esta é uma boa pergunta?
Pontuação 0
1 comentário
is there other warning lights that come on on the dash board ?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi,
Is the check engine light on as well?
Get the vehicle's OBDII port scanned to see if there are any error codes stored.
If there are it may be that the EMC unit has disabled the cruise control due to another malfunction with the engine.
The code(s), if there are any will tell you more about what's happening
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
sandvika72 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 17
Ao todo: 430
