Monitor is off after lightning
Wanna fix the monitor that wrnnt off after over voltage
Esta é uma boa pergunta?
Pontuação 2
5 comentários:
Can you disassemble the monitor, then upload pictures of the circuit boards? Adicionar imagens a uma pergunta já existente
por Compartilhar
jackmotimele104 are you saying that the monitor does not want to turn off? It is on all the time?
por Compartilhar
Did you try another External Power Supply?
por Compartilhar
I'm having the same issue with what looks like almost the same exact monitor: LG 27GL650F-B. Seems like a power surge happened even though I have a surge protector because the monitor flickered, then shut off, and hasn't been able to turn back on since. What tools do I need to fix this and does anyone know how?
por Compartilhar
@ryanarther if anything it'll most likely be the power board. You will have to disassemble your monitor and check the board. As for tools, commonly just a few hand tools (screwdriver set) will do. You may need more once you know what is wrong with it, but for now, just disassemble and evaluate.
por Compartilhar
Adicionar um comentário
