Ir para o conteúdo principal
A quarta geração do Nissan Altima (chassi modelo L32A) foi anunciada no Salão do Automóvel de Nova York em 12 de abril de 2006. Foi o primeiro veículo a utilizar a plataforma D menor da Nissan, com uma nova suspensão dianteira e uma suspensão traseira aprimorada.
07 Nissan Altima Acceleration issue
My Altima has 118k miles, was jerking and hesitant when going into drive and reverse, so I parked it. It had a lean code p171 and p300 misfire code so i changed spark plugs and coils, valve cover and gasket, MAF, cleaned throttle body and checked all the fuses. It still does not accelerate, but the RPMs will go high (past 4k) until i let off gas pedal. Goes into all gears just fine, reverse has no issues now, but when i put in drive it feels like its in limp mode. Checked the alternator and its fine, also car has a new battery too. Im at a loss. I still owe $4k on this car and was quoted $2k for a used installed tranny. I really need help!!! Oh i had a TPS code and a throttle actuator code come up 2101, 123 & 223 then realized I had a loose sensor on the throttle body. I cleared the codes and check engine light went off but still doing it. Please Help!!!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Are you sure its not in limp mode? Also it sound like the auto transmission may be slipping.!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Robin Shepherd será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 326
