Ir para o conteúdo principal
Terceira geração do tablet Surface Pro, lançado em 20 de junho de 2014.
Touch screen not working.
The touch screen isn't working. I purchased a Surface Pro with a bad battery and broken screen. Touch screen was working initially before screen replacement. I've tried two different screens so it doesn't seem to be a hardware issue. All of the drivers appear to be installed properly. I ran the hardware check and everything passed except the touch screen. Is there something I could've broken when replacing the screen and battery?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
There could be missing components from the tablet's board, are you able to look closely around the display connectors to look for any missing parts?
Esta resposta foi útil?
Pontuação 0
1 comentário:
I don't see any missing parts. I connected everything that I disconnected when removing the original screen. Both ribbon cables are connected properly to the panel and the board.
por Compartilhar
Adicionar a sua resposta
Zac será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 14
Ao todo: 306
