Ir para o conteúdo principal
A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
231 Perguntas Visualizar todos
What is the name of the CB300 Chip for replacement?
Found a defective CB300 chip and removed it removing the problem I was facing, looking to identify the chip to order a new one.
Update (01/26/2023)
It's an 820-00239 I've circled the chip in the photo hopefully it's zoomable (it's small)
Esta é uma boa pergunta?
Pontuação 1
2 comentários
hi rich, can you tell us the board number 820- and add a photo of the area
por
have updated now
por
Adicionar um comentário
1 resposta
Solução escolhida
Is it CB300? Or CB308 (which is the one you circled)? CB300 is the one under the little tab in the photo. And that sucker is a magnet for a tiny bit of liquid damage.
Ultimately it doesn't really matter because it looks like both of the components in question are 10μF, 6.3V ceramic capacitors in a 0402 package. Realistically, it is not entirely necessary to replace this capacitor. It may have some minor effect on the longevity of the unit, but if that was the fault, the computer should work just fine without it. Replace it if you are able to do so safely.
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thanks for help! it's the CB308 as circled, I was mistakenly referring to it as the CB300.
por
@Rich Kent No worries, just wanted to make sure I was in the right neighborhood! Happy fixing!
por
Adicionar a sua resposta
Rich Kent será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 44
