Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
1697 Perguntas Visualizar todos
Power supply connector ripped off CUH-1206B
Hello! I messed up.
In the attempt of changing my PS4's (fat with physical buttons CUH1206B) thermal paste and pads, I ripped off the power supply connector in the motherboard. Below are some images.
The motherboard with ripped pads:
The connector:
The connector place in it's proper position on the board:
I have never messed with soldering, but I do intend to try fixing it as buying another PS4 is just impossible for me right now, so the simpler the solution, the better. I'm following other tutorials on this but I can't seem to figure out where the traces for the upmost left connector go, any ideas?
Thanks in advance, this console is very important to me and the moment I'm living.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
***arthurc.victor darn tore the solder pads off too. Well, you will need to solder some jumpers. See the attached image. You wil need to scrape the green masking off. Use a thin sharp object for that. I prefer a scalpel (available at plenty of places like hardware stores/feed stores and department stores). Then get yourself some enamel wire and solder the connection to the points on the board. Your connector will be pretty loose, I would use some good adhesive (no, not crazy glue) and adhere it to the board. Since you have never done this, practice on an old board first. It's not as easy as it looks :-) if you have never done it.
Esta resposta foi útil?
Pontuação 1
5 comentários:
Thank you for the help, but I have one doubt: the yellow dot would be ground? As in, just scrape the board and solder. And the purple line, should I solder to that square right next to it? Don't wanna risk frying the board, thanks again.
por
The red line, I’d just solder to the trace right next to it and not all that way. Neater too.
por
@strongbow i thought about that as well but went the path of least resistance. It’s a PITA to solder on that small trace :-) old eyes and shaky hands need a bigger connection point. ;-)
por
@arthurc.victor yes you can solder right on that pad. I just wanted to mark the general area for that
por
@oldturkey03 I'm thinking microscope so it would be massive lol. Which ever would be easiest to get it working again. 👍
por
Adicionar a sua resposta
arthurc.victor será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 352
