Ir para o conteúdo principal
Samsung. número do modelo: LN32A450C1D, código do modelo: LN32A450C1DXZA Fabricado em setembro de 2008
Minha televisão n tem imagem
Minha televisão n t imagens
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
luiscarlossilvaluiscarlos413 does it have sound? What have you checked?
Translation
luiscarlossilvaluiscarlos413 tem som? O que é que já verificou?
por Compartilhar
Adicionar um comentário
4 respostas
luiscarlossilvaluiscarlos413first you need to rule out your inputs as error source. Remove all of them (especially if you have some sort of cable box, sat box etc.). Unplug your TV and unplug all input sources. Hold down the power button for 30-60 sec. Then reconnect one input source (preferably local, something like Game console, DVD/BR player). and make sure you use a known-well HDMI cable, if that's how you connect. Lastly reconnect the TV and try to turn it on. See if that changes anything.
The no video issue can be related to a bad backlight inverter circuitry. A simple check for that would be to darken the room and turn the TV on. Then use a flashlight and angle the light at the screen on different areas. you might make out some shadows or see a slight grey color. Your model uses an backlight circuit on the power supply board.
If you do not see anything it's time to remove the back cover from your TV. Check all the boards for damaged components and reseat all the ribbon cables. Measure the voltage on your T-Con board. Next to the connector is a Fuse marked as F1. You should have 12V on that. Next check the connector that has the cable from the main board in it. Make sure that you have all the voltages on that connector and pay particular attention to the BL_On
Take some pictures of your boards and post those with your Question. Use this guide Adicionar imagens a uma pergunta já existente for that
TRANSLATION
luiscarlossilvaluiscarlos413 primeiro precisa de descartar as suas entradas como fonte de erro. Remova todos eles (especialmente se tiver algum tipo de caixa de cabos, caixa de satélites, etc.). Desligue a sua TV e desligue todas as fontes de entrada. Mantenha premido o botão de alimentação durante 30-60 segundos. Depois volte a ligar uma fonte de entrada (de preferência local, algo como consola de jogos, leitor de DVD/BR). e certifique-se de usar um cabo HDMI bem conhecido, se é assim que se liga. Por fim, volte a ligar a televisão e tente ligá-la. Veja se isso muda alguma coisa.
O problema do vídeo não pode ser relacionado com um mau circuito inversor de retroiluminação. Uma simples verificação para isso seria escurecer a sala e ligar o televisor. Depois, use uma lanterna e faça um ângulo da luz no ecrã em diferentes áreas. poderá fazer algumas sombras ou ver uma ligeira cor cinzenta. O seu modelo utiliza um circuito de retroiluminação na placa de alimentação.
Se não vir nada, é altura de retirar a tampa traseira da sua televisão. Verifique todas as placas em busca de componentes danificados e volte a colocar todos os cabos de fita adesiva. Meça a tensão na sua placa de T-Con. Ao lado do conector está um Fusível marcado como F1. Deve ter 12V nessa placa. Em seguida, verifique o conector que tem o cabo da placa principal. Certifique-se de que tem todas as tensões nesse conector e preste especial atenção ao BL_On
Tire algumas fotografias dos seus quadros e afixe as que têm a sua Pergunta. Use este guia Adicionar imagens a uma pergunta já existente para isso
Esta resposta foi útil?
Pontuação 0
2 comentários:
Minha tv tem 11 anos de uso e agora ela apareceu umas listras vermelha e não tem imagem só a listras vermelha
por Compartilhar
@geovanecos24588 what exact make and model is your TV? What have you checked? It is possible that this is a bad main board or a bad panel. We really would need to see what it is that your screen shows you.
Translate
@geovanecos24588 qual é a marca e o modelo exactos do teu televisor? O que verificaste? É possível que se trate de uma má placa principal ou de um mau painel. Precisamos de ver o que é que o teu ecrã te mostra.
por Compartilhar
Se a sua televisão Samsung LN32A450C1D não está exibindo imagem, há vários possíveis motivos, incluindo problemas no cabo de vídeo, na fonte de alimentação ou no próprio painel de tela. Aqui estão algumas coisas que você pode tentar para resolver o problema:
Verificar o cabo de vídeo: Verifique se o cabo de vídeo está conectado corretamente em ambos os lados e se não está danificado. Troque o cabo, se necessário.
Verificar a fonte de alimentação: Verifique se a fonte de alimentação está conectada corretamente e se não há problemas com o cabo de alimentação ou o próprio adaptador de alimentação.
Verificar as configurações da TV: Verifique as configurações de entrada na TV para garantir que esteja selecionada a fonte correta.
Verificar o painel de tela: Verifique se há problemas no painel de tela da TV, como pixels danificados ou outros danos físicos.
Se essas verificações não resolverem o problema, é recomendável levar a TV para uma assistência técnica para uma verificação mais aprofundada.
Pontuação 0
Tenho caso assim. O problema é que nos 12v (existe) e ai conectar a tcon cai para 4,7v. Não é a tcon+já coloquei 2 para teste e dá a mesma coisa)...
Pontuação 0
1 comentário:
Se desconectar cabo para vcon tbm nso muda bada. Os 12 continuam caindo para 4,7 e sem imagem. Mas a tela está acesa como se vê pelos orifícios do chassi
por Compartilhar
Vosse quando com prou a televisão pode ter tirado uma película que e a principal para dar imagem
Pontuação 0
Adicionar a sua resposta
luiscarlossilvaluiscarlos413 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 13
Ao todo: 760
