adhesive recommendation for re-assembly
i'm looking for an adhesive recommendation to re-assemble a repaired Gotcha Evolve. when i (very carefully) took it apart there was a bead of glue around the inner case perimeter (reminded me a lot of hot glue-gun glue). it was very tacky but very flexible. adhesion was good as it took a while to pry it off the base side.
i'd like to find something that
A) does a good job of holding the top and bottom together
B) would still enable the separation of top and bottom (using the same technique of a thin blade or spudger to pry them apart without breaking them, in case i need to do further repairs
C) keep it's form when dispensed, unlike liquid glue that would just flow everywhere (self-leveling i think is the correct term). if i put a seam of it down, i want it to hold that shape until i press the two pieces together.
any thoughts?
Esta é uma boa pergunta?
