LG TV not turning on
Hi,
I have an LG TV 65UM7300AUE and it won't turn on. There is no red light on the IR sensor and I've followed all the basic troubleshooting. After that I have been buying parts from ebay, trying each one to see if it fixes the issue. I tried replacing the power supply board, main video board, IR button and sensor, IR/WIFI cable and lastly the power supply board to main video board power cable and it's still not turning on. I'm at a loss of what's going on with the TV. Any suggestions or help is appreciated.
Esta é uma boa pergunta?
3 comentários
@gabrielomarpr does it give you any sign of life at all? Any power LED light when you plug it in? Have you checked if you get power to the power board? It will be there even if you do not turn the set on. Do you still have the back cover off? Can you post pictures of the complete back and the individual boards with your QUESTION? That way we can see what you see. Adicionar imagens a uma pergunta já existente
por oldturkey03
Thanks for the comment. There's no signs of life at all. No LED light on when plugged in. I do have a multimeter but I honestly don't know how to measure voltage on this. I added images to the OP for reference.
por Gabriel Ramirez
I have an LG Smart TV 60PH6710 which almost do the same thing however when you plug it on the mains red light turns on standby then it quickly powers up and after 2sec it goiez ba L to standby mode.
por Nkosinathi E Manyathi
