Flashing E2 & F2 codes. Won't start
I have this same issue. Took it apart and replaced the user interface. It’s still happening!
Esta é uma boa pergunta?
Hi @lbaas
Since you have replaced the UI and also that you have checked the wiring harness connections (loose, corroded etc) between the UI and the main control board, check if there is 5V DC between control board connector P1C pin 2 and P1C pin 4.
If not, replace the control board. The part number for the control board is W10751502. Search online using the part number only to find suppliers that suit you best.
Here's the tech sheet that may help. Go to p.2 to view the wiring diagram
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 46
4 comentários
@lbaas
What is the model number of the dishwasher?
por jayeff
@jayeff it appears to be W10632081A
por Laurie
@lbaas
Is there a model number tag is located inside the dishwasher on the tub frame with a WDT # or WDF # on it?
Having trouble finding service info using the number you posted.
por jayeff
@jayeff, looking at it now. WDT720PADW1
por Laurie
