Ir para o conteúdo principal
Um controle em formato de guitarra para o Guitar Hero III da franquia de jogos Guitar Hero.
Fret Button Malfunction - Blue Button is always on
I recently bought a guitar hero 3 les paul controller for PS3. When I tested it I noticed the Blue Button is pressed automatically every time I play a song. I tried cleaning the contacts on the PCB (Fret Buttons) with IPA and Pencil Eraser. It would work for a couple of songs (meaning the Blue Button is not pressed) BUT it will go back to its previous condition where the Blue Button is pressed automatically. I only played on EASY difficulty, it still gone back to being pressed. Tried changing the (Blue) Button Pads with Gray ones, still same effect. Need help on how to fix this.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
it may have to do with the fact that the neck is removable, eventually the connection between the neck and body becomes compromised. Try putting a rubber shim behind the small board where the neck connects so there is always a proper connection. (have you tried a new set of batteries?)
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Arcee Ariola será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 15
Ao todo: 757
