How To fix "Card Error" when using SD card.
My camera seems to be having trouble wit SD cards. I have tried multiple but it always says "Card Error"
Esta é uma boa pergunta?
You may want to check that your Olympus E-PL1 camera's SD Card reader is not corroded or damaged in any other way. Check for bent internal prongs or small debris within the slot.
Esta resposta foi útil?
Card Error issue is not always caused by hardware damage, sometimes when I use the card into other brand, such as sony, it will show Card Error.
This issue caused by Olympus trying to check the files in the card.
My fix is by removing other folders beside "DCIM"
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 42
Ao todo: 1,062
