Is the Bluetooth board interchangeable
Can you use the Bluetooth board in the studio 2 to get Apple w1 chip in the better colors headphones
Esta é uma boa pergunta?
Hi
Unfortunately I don’t thing doing a board swap is possible because there are lots of small wires and they could all go to different places on the boards,there could also be extra cable in there too;-{
However
If you wanted you could take them apart and see if you could jerryrig some of the parts to fit together (some might need some things cut off on the inside in order for them to fit)as the plastic pieces on the studio 2 and 3 are very similar
Hopefully this helps
Any questions please ask
Esta resposta foi útil?
Thanks I will see if I’m that adventurous when I get my new battery for my headphones
@Dave Hall
Sounds like a plan!
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Ao todo: 582
