Broken screen replacement 16 inch 2,5K
Can anyone post step by step replacement of the 16 inch screen for this laptop
Esta é uma boa pergunta?
Hi,
Here's the hardware maintenance manual for a Lenovo Ideapad 5 Pro-16ACH6 - Type 82L5 laptop which I assume is the model that you're referring to.
Go to p.39 to view the procedure to remove the LCD panel.
Here's a link to the parts list for the laptop.
Click on Select Commodity > LCD Panels (9) to find the part number for all the LCD panels that can be used in the model. Usually the part number can be found on the back of the LCD panel somewhere, if you wish to verify which one is the one used in your particular laptop. Search online using the part number only to find suppliers that suit you best.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 18
Duração total: 477
