Why is the charger saying the battery is charging but It’s not
When I put the battery on the charger it says it’s charging but when I take it off the battery and try to use it it’s completely dead what do I try to fix it
Esta é uma boa pergunta?
Hi,
What is the model number of the camera?
Are you charging the battery whilst it is still in the camera or are you charging it removed from the camera?
It could be something as simple as a failed battery. Try replacing the battery and check if that resolves the problem. Even rechargeable batteries have a lifespan.
Esta resposta foi útil?
i took it out the camera and put the battery in the charger and the model is panasonic palmcord pv-v425d
@ benjamin cenan
Don't know the model but have you checked the battery with a voltmeter to see what its voltage is after it has been "charged"?
@jayeff the battery won’t charge it had been on the charger for 1 day and it still says it’s charging
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 51
