Ir para o conteúdo principal
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
How to restore with itunes?
my ipad says it needs me to connect to itunes to restore it so that i can use it and it says that ipad is disabled. What do i do?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
it's simple: connect your iPad to your computer and launch iTunes (if it's PC). If you are connecting to a Apple/Mac, run finder app. Everything will start automatically. In case the tablet is disabled, insert the cable into the computer then, while holding down the home button in ipad, connect the plug to the tablet (still keeping the home button pressed). After a few moments, the tablet will start in service mode and iTunes (or finder) will ask you whether to update the iPad or restore it (removing all saved data irretrievably). If your data is stored in iCloud, it will be recovered when you install the device (after restor). Update mode do not remowing any data.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
tayola será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Ao todo: 310
