Ir para o conteúdo principal
WiFi connection with Android
How can I get my Android phone Oppo F11 pro see the Drone Wifi signal? I have tried for the past 3 days and the drone doesn't seem to have it's wifi visible for my Android to see. I need help please. if there are preferred compactible phones I will like to know.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Did you check of your drone is accessible from other phones?
If so - check if your drone's wifi is 2,4 GHz signal and not 5 GHz, since if you have an older phone it may not properly support 5 GHz. Also if your drone has a wifi channel selection option - make sure it's a channel between 1 and 10 to keep it on the safe side. Hope this helps.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Victor okechukwu será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 19
Ao todo: 450
