Ir para o conteúdo principal
Sony Cyber-shot DSC-RX10 III - Released 2016, 600mm Zoom
Advice on Main board replacement
problem 1: need to replace my broken one inside the camera
Problem 2: camera repair centers say authorized Sony repair centers wont accept used parts, such as the used main board I have to put in the camera
what do you think? Do I absolutely need to buy a new part?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Evan Girard no you do not. Used parts are okay to install, just not through an authorized service centers. They do not accept your used parts because they could not guarantee their repair and would not make any money of you. You can most certainly install most parts yourself.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Where did you get the main board from? I need to replace mine but there seems to be several options ranging from cheap to expensive
por
Adicionar a sua resposta
Evan Girard será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 211
