Ir para o conteúdo principal
Ferramenta profissional usada provavelmente para a manutenção de celulares Nokia. O dispositivo foi projetado como um dongle com um leitor de cartão interno.
I didn't know the e-composite reference
can you help me? This electronic component, as in the picture, was removed from the xtw100 device, and I did not find it. I want to know its full name, quartz, and its reference, in order to replace it or change it with an alternative. Please help me and thanks.
Imagem
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Here's a link that shows the schematic for the programmer.
The crystal oscillator schematic component ref ID is Y2 and it has a frequency of 8MHz as can also be seen on the component in the image you posted. There is no other information as to its other specifications i.e. load capacitance, drive level, ESR etc so it will be difficult to know what the exact replacement would be. (examples only).
It may save a lot of time and hassles if you just purchased a new programmer. (supplier example only) as they are not that expensive.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Ahmed Paradoox será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 28
Ao todo: 560
