Kindle 10 damaged USB port and circuit board solder points
I have a Kindle 10 with a damaged USB port, and the PC board traces are damaged as well. I can catch a piece of the power connections, but the data connections (pins 2 and 3 I believe) are a mystery. Do the pins correspond to any of the TP's on the pc board? I tried a continuity test from the serial connections to the connector on a different generation unit, but it does not look like that's it. Thanks!!
Here's a closeup with the port removed.
Esta é uma boa pergunta?
5 comentários
post a close up photo of the damage
por daniel
[image|2824470]
por Charles Deel
@deelio sorry but i can't see it, it just says image 2824470
por daniel
@deelio, comments don't support images, so I edited your question to include the picture.
por Jerry Wheeler
@deelio can you clean the area with ipa, its kind of messy. once you do you may see where the traces lead too
por daniel
