2006 Nissan Altima was parked for 5 months and was now super hard to i
2006 Nissan Altima was parked for 5 months was fine when parked but now is very hard to start and knocking any ideas?
Esta é uma boa pergunta?
There are several possibilities, you can try. I would start by checking all the fluids and the battery condition. When I say fluids, I mean everything -- engine, transmission, brakes, coolant, and rear end. If any of the fluids seem abnormally low or thickened, consider topping off or replacing, and change your filters. Keep reading below and I'll leave that decision to your good judgment.
If you've already cranked or even started the engine, the next step I'm considering can probably be skipped. What I'm thinking about is the piston cylinders may have developed a very thin film of rust on the inside surfaces. Normally running the engine every so often keeps this cleaned off and all surfaces get a fresh coating of oil throughout the engine. What I would consider doing is pulling the plugs and hand-crank the engine with a big wrench. This step is NOT intended to actually jump start the engine, and don't do this if you've never seen it done before. And certainly don't do any hand cranking if the engine is in a state that it could fire up and try to run.
If you were already able to get it running, but it is running poorly, consider replacing the all the fuel. Regular gasoline can degrade in 3 to 6 months, ethanol-based fuels can lose its combustibility in 1 to 3 months, and diesel can last up to a year. Finally, consider taking it to a repair shop you trust. In fact, a professional once-over is advisable even if you do get it running.
When I was in the US Navy, some of us would have to put our vehicles in to storage for 6 to 12 months or even longer while overseas. And if you need to do this again, you can see in the list below, that the process is very involved:
To put back into service: a full inspection of the electrical components is needed. All preservation oils must be removed and refilled with manufacturer approved oil. Coolant should be tested and refilled, if necessary. And finally check tire pressures before attempting to drive.
Alternatively, a number of people I know, would ask a friend or relative relative to babysit the vehicle by starting it about once per month to fully warm it up, and even drive it around for a day or two. I'm doing this sort of thing now for a relative spending a year and a half working in Mexico. This sort of thing is what I called "pickling the engine".
Best of luck with this, Doug
Esta resposta foi útil?
My main concern is the knocking when it is started
Gasoline has a shelf life and it starts to degrade after about 3 - 6 months so maybe this is causing the problem.
You may have to replace the gas in the tank and flush through the lines, filters etc and then check
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 8
Duração total: 58
My main concern is the knocking when the engine is started and what would cause this
por Ryan Leatherman
