Ir para o conteúdo principal
ASUS TUF Gaming Laptop - FX505D-DBQ234T com i5-8750H e Nvidia GeForce GTX. MFD-2019-05.
windows button is not working
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Pergunta mais útil
got the same issue. wasted my two days try to find out what was wrong, well maybe a bit late but here is what happened
you may enabled the STUPID Win key disable function by accidentally pressed the Fn and Win, which is conveniently placed NEXT TO EACH OTHER, and just make things worse, there is no indicator light like the caplock, so good luck to find that out. Thanks Asus
Esta resposta foi útil?
Pontuação 5
3 comentários:
Wow! Amazing!!
You helped me the most
I spent a few hours trying to restart the computer, update BIOS and only your answer helped me
Thank you!!!!!!!!!!!!!!!!!!!!!!!
I signed up to the site just to thank you
por Compartilhar
Hey Thank you from me too, I had to ask one colleague of mine who was younger than me, he did not tell me how to do it instead was showing off a little.
Now I can fix it myself.
por Compartilhar
Thanks brother this helped a lot ❤️
por Compartilhar
Well you can try the following solution
  1. Reset your PC
  2. Sign in with your Local Account
  3. Reboot your Device
  4. Close Windows Explorer
For more you can read this
Pontuação 1
Hi,
Here's a link regarding what to check if the Windows key is not working.
Pontuação 1
Hey Team ! If window button is not working in ASUS Please turn off gaming mode in setting's
Thanks.
Pontuação 0
Adicionar a sua resposta
nc5821 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 19
Ao todo: 581
