Ir para o conteúdo principal
Guias de reparo, desmontagem e informações de resolução de problemas para a 7ª geração do Apple iPad com Wi-Fi, disponível com 32 ou 128 GB de armazenamento. Lançado em setembro de 2019. Identificado pelo número de modelo A2197.
Screen ghosting/Shadow on Led.
I cleaned the lightning port with electrical contact cleaner, worked great.
now the LED screen appears to have some ghosting/shadows behind the image. never had this issue before.
Is this fixable? or do i need to replace the LED.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi Oliver,
Depending on how heavily you doused the port with the contact cleaner, it's possible some of it made its way inside and got onto the LED/backlight/polarizer assembly. We've seen cases where a similar thing happened with isopropyl alcohol, and luckily after a couple of days the alcohol finally evaporated and left the screen okay.
In your case I'd suggest giving it some time to allow for the cleaner to dissipate; it may fix itself all on its own. If it still looks like that in a week then it might be worth considering a screen replacement.
Let us know what happens; if it doesn't clear up on its own, add some pictures to your question of what you're seeing and we'll see what we can do for you then.
Esta resposta foi útil?
Pontuação 1
The first thing you should do if you're dealing with the ghost touch issue is to force restart your device. This will refresh the memory and reload all services. Needless to say, it brings your iPad back to its normal operation.
Regards,
Will
Pontuação -1
1 comentário:
@willjoe it’s not a touch issue it’s an image issue.
por Compartilhar
Adicionar a sua resposta
Oliver Byrne será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 27
Ao todo: 572
