Ir para o conteúdo principal
The PowerBook 100 series kickstarted Apple's line of PowerBooks.
How can I recover data from the HDD (Conner CP2045)?
I'm trying to recover the files from the hard drive of a PowerBook 100.
The HDD is a Conner CP2045 and as far as I have figured it out it has a SCSI connection. Any thoughts?
Thanks for any assistance.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
see if you can find a Belkin USB to SCSI adapter (none of those are cheap) Something like an F5U115-UNV should work. Take a look on here for more on that. Another idea might be something like this which might give you an IDE inerface. Then convert that to USB with another adapter or connect to an IDE compatible computer. Not an easy or inexpensive project, but definitely fun.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Aléxändru Mihaì será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 185
