Ir para o conteúdo principal
The Samsung Galaxy A10s is an Android smartphone developed by Samsung Electronics, and was released in March of 2019.
microphone is not working properly
How to fix Microphone that is not working properly?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Samsung MIC problem solution
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi,
Can you be heard OK when using the phone in speakerphone mode (aka hands free mode) or when using earphones with a microphone attachment plugged into the phone's headphone socket?
If so then there may be a problem with the phone's main microphone only and not the voice transmission circuitry in the phone.
Is the phone in a protective case at all?
If so, remove it from the case and check if it now works OK. If it now works OK the case may be blocking the voice inlet hole located on the bottom edge of the phone between the charge port and the headphone socket.
If it is not in a case or it still doesn't work when removed from the case check that the voice inlet hole on the bottom edge of the phone is not blocked with lint etc.
It may be hard to tell if it is or not, but do not use a metal pin or probe to try and clear it anyway as you may damage the microphone which is behind the hole. Try using a vacuum cleaner and check if this clears any blockage and resolves the problem.
If still no good it may be a faulty microphone.
The microphone is part of the charge port and mic board (supplier example only - search online for Galaxy A10s Charging Port Dock Connector Microphone Board to find suppliers that suit you best).
Here's a video that shows how to replace it.
Esta resposta foi útil?
Pontuação 1
Tried sticking a head pin in and out a few times. IT WORKED like a charm.
Please try this before any other elaborate suggestions.
Pontuação 0
Adicionar a sua resposta
Russel S será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 26
Ao todo: 583
