Why is my touchpad turning off and on by itself all the time?
it is always turning off when i use my touchpad
so i just switched with my mouse which is inconvenient and bulky
any suggestions / fixes?
Esta é uma boa pergunta?
Software
Check drivers are good in DeviceManager:
Type devmgmt.msc in Start Menu. Delete Touchpad but not the drivers. Then at Menu click Action and "Scan for hardware changes". The drivers will be re-installed by Windows. Touchpad should work now. If not check below.
Try booting up in Safe Mode and see if it works there. If all is fine some other software could be interfering with the TouchPad's drivers.
Hardware
Check that all connections are secure:
HP Pavilion dv6500 Touchpad Replacement
If still not working then you may have to replace the TouchPad.
Here is one possible source but pick your own:
Esta resposta foi útil?
TBH I'd just tap a lead and buy a nVidia unit if I needed parts ;). Dead or alive, I'd canabilize one of those.
The motherboard instantly devalues them to the parts bin, so I would have everything but a heatsink and motherboard to play with for future spare parts too.
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 59
