Lit match to close to tv now white speks are on it
I lit a match and sparks got on the tv how do i get them off
Update (12/15/2022)
[image|new_window=true] trewhhhhh
Esta é uma boa pergunta?
logangvr1 possible that those are burn marks. We would need to see what they look like. If they are as I suspect, then you really can't do a whole lot other than try to wipe down the screen surface. To add images, use this guide Adicionar imagens a uma pergunta já existente
That was quite a match. Anyhow, this looks like it damaged (burn holes) in your screen and there is nothing you can do about it. Unless you find another identical screen and harvest replacement diffuser and polarizer sheets from it.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 48
