Ir para o conteúdo principal
Um notebook voltado para o consumidor com tela LCD HD de 15,6", Bluetooth e um touchpad totalmente funcional.
Replacement battery discharge rate?
I just replace the battery (PX03XL) and am wondering what I should expect for battery life. I realize it is an old laptop, approx. 9 yrs old, but I only seem to get about 3 to 3.5 hours of combined use before needing a recharge. Usage is mostly e-mail, web browsing and idle time. Keyboard backlight is off and display is approximately 70% brightness. Is my expectation for 6 to 7 hours unrealistic? Is 3 to 3.5 hours about right?
Thank you.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
What are the capacity of the new and old battery? Get HWInfo and monitor the average power draw over a full charge-discharge cycle and then compare it to the rated capacity to calculate the expected runtime.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Yikes way too complicated! How would I monitor power draw.
But thanks for responding.
por
@Dave B theres an application called hardwareinfo which shows the current state of all the things inside your laptop including power draw. aside from that i think 3-4 hours of battery life is a reasonable expectation for a 9 year old laptop with a replaced battery.
por
Camden, I like your "aside" comment. Thank you!
por
Adicionar a sua resposta
Dave B será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 399
