Ir para o conteúdo principal
A iO, lançada em 2020, é uma escova de dentes elétrica da Oral-B. Ela é capaz de se conectar ao seu smartphone via Bluetooth e oferece rastreamento 3D dos dentes em tempo real. Identificada pelo número de tipo 3758. Os modelos incluem: iO Series 7, iO Series 8, iO Series 9 e iO Series 10.
Can't start after replacing battery
Hi, why my oral b io doesn't work after battery replacement? The guide is fool proof however, something goes wrong.
Thanks for your help
Esta é uma boa pergunta?
Pontuação 1
7 comentários
Hi @juanpulag,
Did you put the battery in the correct way? Maybe double check.
Did you charge the battery first after installing it, before attempting to turn on the toothbrush?
por
What battery type did you replace with? Do you have a multimeter?
por
@andrewsawesome Hi Andrew, thanks... I don't have a multimeter, so I can say that even the original battery doesn't start the brush.
What can I do with a multimeter? Thank for your answer....
por
@juanpulag I was going to ask you to check the voltage of the battery with a multimeter.
por
@jayeff hi, neither new and old battery works, the brush just shut down permanently... So sad, that's was something easy to solve "was"
por
Exibir mais 2 comentários
Adicionar um comentário
1 resposta
Solução escolhida
Sorry to be late to the party, but a german user just posted a comment with the same problem and the solution: He managed to reset the io via the app and it works flawlessly since then.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Diego será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 63
Ao todo: 3,444
