Ir para o conteúdo principal
Modelo A1419 / Final de 2013 / Processador Core i5 de 3,2 & 3,4 GHz ou Core i7 de 3,5 GHz, ID iMac14,2
Using BootCamp and insalling it on second drive of system.
I have upgraded an second hand Imac that had a 1TB hard drive with an I7 upgrade and Replace the 1TB mechanical HD with a 1TB SSD and also installed a 1TB NVMe drive with and apple adaptor. I have been able to install a fresh copy Catalina on it and have been trying to install windows 10 on it also. I keep having errors with bootcamp. When I try to create the windows 10 install disk it give me an error formatting drive. I have searched for help on the internet but what am I doing wrong? Any help would be great.
Thanks
Mike
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
I'd suggest you use an installer USB drive created on a PC - boot from that and do a clean install of Windows on the internal SSD (wiping it in the process). If you also want MacOS put that on a second (external?) drive. Windows will usually install itself pretty well on a bare Mac but sometimes you have to find drivers for the various bits of hardware. Bootcamp isn't a great source of drivers most are old and may not work with Windows 10.
Update (12/12/2022)
With a separate drive to install Windows there is no need to use BootCamp. Here I have a 2012 MacBook with the Windows USB installer inserted. Holding down the Option key when booting the Mac will allow you to boot from the USB drive and install Windows on any internal SSD or HDD. If you have made the BootCamp disk it may be useful as a source of Windows drivers but you can usually find better ones elsewhere.
Imagem
Imagem
Imagem
Esta resposta foi útil?
Pontuação 0
5 comentários:
Ok already tried I get cant find boot drive error.
por
I'm suggesting you put the Windows USB installer (created on a PC) into the iMac and boot from that. So you'll be running a bog standard Windows installation onto the internal SSD. Hold down the Option/Alt key to choose the USB stick as the boot disk.
por
John this is a dual boot setup, it is not running BootCamp. This works too! But you can’t flip between access of each without rebooting.
BootCamp allows you to share data files. As an example for a time there was more effective audio composing and DJ tools in Windows, yet better animation tools in macOS. So many Pros needed to jump between.
por
Correct Dan. It works and you don't need to buy an Apple SSD!! Who would seriously do that? There are plenty of other ways to exchange files between MacOS and Windows without using BootCamp (use ExFAT formatted partitions or USB drives). BootCamp was probably only created because it was so difficult to add extra drives to the iMac—Windows will only boot from an internal drive. Since the OP has multiple drives there's no need to use it. I use VMware to run old software in Windows XP and it's great - don't even need to reboot but having Windows on it's own drive is much more reliable and versatile. The Windows system doesn't rely on the MacOS to keep working, you can even move the drive back to a PC and it'll work.
por
@John - True an external drive can shuttle files across two discreet systems!
The rub here is within a single system having to reboot between the two environments takes time and if you forget something it can be tedious flipping between!
As far as Apple blade SSD this is needed only internally that’s a hardware limit within the older systems which used Advanced Host Controller Interface (AHCI) blade SSD’s like this one if you use it as the boot drive with non-Apple PCIe/NVMe drives with the newer APFS file system which is now required newer than Mojave.
Basically, this series needs a AHCI blade drive if he wants Dual boot from it as the systems firmware won’t allow MS Windows to boot from a PCIe/NVMe drive internally.
por
BootCamp can only run from the boot drive. This is an Apple limitation.
Even still you appear to be having a more basic issue, from your description it sounds like you are using a M.2 SSD with an adapter. These can be tricky! More so when used in an iMac as it’s a bear to go back in maybe two or three times trying to get it to work. Frankly, they are more of a pain than worth it.
I would stick with either a real Apple SSD or use the OWC SSD which is a true pin compatible drive. Yes, both are more expensive you can thank Apple for not sticking to an industry standard.
I would also run Apples Disk Utility from your HDD until you can see the drive within it. If you can’t the connection and/or the adapter and SSD are bad.
Imagem de Replace or upgrade the PCIe solid-state drive in a variety of Macs.
Produto
OWC Aura Pro X2 SSD
$434.99
Pontuação 0
9 comentários:
The ssd adaptor works fine. I can boot and run of the drive with no problem. Im having problems with boot cam not letting me make a install disk. Also when I made one on the PC it gave me boot drive not fount error
por
@Michael Galano - Why did you use a PC? That will mess up the Mac file system if you want to use BootCamp as the primary partition must be either HFS+ or with the newer OS’s APFS.
Clean the drive off of all the partitions and start again formatting the drive using macOS and install it. Make sure it works and you are booting up under that drive. Then setup BootCamp following Apples guide on this drive.
por
But what's the point of using BootCamp? - no need if you have two drives. Use the Alt key to choose which system disk to boot from.
por
@John - Are you confusing dual boot with BootCamp?
You may want to read up on what BootCamp is as well as what a Virtual Machine (VM) is. These run on top of a different OS Vs running independently with a dual boot. I have a multi-boot system which runs MS-DOS, MS Windows and Linux. Within a single drive each sitting in a different partition.
Here BootCamp sits on top of macOS in a special folder and you have a second volume on the drive to hold your windows files. If you want you can add more drives to hold your stuff (Data Files) in the same way you can within MacOS or even MS Windows! But that is not where Windows the OS files sit.
por
@danj - no I'm not and I've used Bootcamp, VMware, Parallels in the past - and I can tell you a standalone Windows install is the best solution.
por
Exibir mais 4 comentários
I had this problem too but after many dead ends trying to format my iMac's second drive for Windows I found WinClone (it's $50 however it was FREE to download and use!)
It worked great and the video was super helpful.
https://www.youtube.com/watch?v=H34UJ6YR...
https://twocanoes.com/products/mac/wincl...
Pontuação 0
Adicionar a sua resposta
Michael Galano será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 45
Ao todo: 3,266
