Ir para o conteúdo principal
A Radeon RX 460 é uma placa gráfica da AMD, lançada em 8 de agosto de 2016. Construída com o processo de 14 nm e baseada no processador gráfico Baffin, na sua variante Baffin PRO, a placa oferece suporte ao DirectX 12.
How to repair it?
How to repair Radeon RX 460? No signal to monitor, I played Starbound and when i teleported to ship, i saw white lines, i ignored em and she died, i want her back.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
It's difficult to say exactly how to repair a Radeon RX 460 without more information, but there are a few steps you can try that may help:
  1. Make sure that the cables connecting your monitor to your graphics card are securely plugged in at both ends.
  2. Try unplugging the power cables from your computer and plugging them back in to reset the hardware.
  3. Check the settings on your monitor to make sure it is set to the correct input source (HDMI, DisplayPort, etc.)
  4. If your graphics card has a separate power cable, make sure it is securely plugged in.
If these steps don't help, it's possible that your graphics card has failed and will need to be replaced.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Marian-Gabriel Ionita será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 25
Ao todo: 993
