CPU and CPU Fans didn’t turn on
Why only my cpu and cpu fans didn’t turn on? All other components working just fine. Sometimes it turn on or because my extended 8pin CPU power cable?
Esta é uma boa pergunta?
Hi,
It could be a faulty fan or as I said it's not passing POST.
If the CPU fan is not working then most likely the CPU will be shutdown to prevent any damage occurring to it due to overheating.
Most CPU fans have an rpm sensor and also a temp sensor embedded in them so that the BIOS knows what speed the fan is operating at (which also lets it know that it is working) plus the temp of the air being drawn over the CPU so it know how hot it is.
Being sometimes intermittent the quickest way to know what's happening is to connect a system speaker (known as a chassis speaker in the user manual for your motherboard) to the motherboard and check for any beep error codes when the PC is first started - see images below for connection location and code meaning
(click on images)
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 108
2 comentários
Hi,
More inoromation is needed to help you to fix it.
Has the PC worked OK before or is this a new build?
What is the make and model number of the motherboard if a custom build?
What is the make and model number of the CPU?
What is the make and model of the PSU, GPU card (if applicable) and how much ram?
There are a lot of reasons why a PC may not start.
Have you got a system speaker (supplier example only) connected to the appropriate motherboard header pins to check if there are any beep error codes on startup? The PC may not be passing POST (Power On Self Test)
What have you tried?
por jayeff
PC worked perfectly fine before, yesterday when i playing games my monitor suddenly black then i look at pc only cpu fan stop working then i turn it off and wait 1hour try to turn on same thing only CPU fan not working no display. Today i try again all working fine just for 10minutes.
Mobo: Asrock Steel Legend B450m
CPU: R5 5600x
GPU: TUF RTX3080 Ti 12GB
PSU: Cooler Master MWE 850 V2 Gold
RAM: T-Force Delta 16GB 3200mhz (4 pcs)
Other accessories keyboard, mouse and headphone nothing more.
por Hae Erry
